Reply
RBS50 Unable to update to latest firmware v2.1.1.16 from v2.0.0.74
fydela2
Tutor
unable to update to latest firmware v2.1.1.16 on RBS50 (satellite), getting pop-up below while following instructions (https://kb.netgear.com/000053128/RBR50-RBS50-Firmware-Version-2-1-1-16). Tried firefox but same result. Tried ethernet connect to satellite and same result.
<html><head><meta http-equiv='Pragma' content='no-cache'><meta http-equiv='Cache-Control' content='no-cache'><title> 401 Authorization</title>
<script language="javascript" type="text/javascript">
function cancelevent()
	top.location.href='/unauth.cgi';
</script>
</head><body onload=cancelevent()></body></html>
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 4
Orbi
Star
Re: RBS50 Unable to update to latest firmware v2.1.1.16 from v2.0.0.74
Try moving satellite closer and do a factory reset on the satellite.  Also, the process seemed to take atleast 6 minutes - 10 minutes for it to sync.  The issue might be because it wouldnt sync with the router.  I had to flash back to the 2.0.0.74 cause there was sync issues.
Message 2 of 4
fydela2
Tutor
Thank you for the quick response.
It is currently running v2.0.0.74. Tried wifi right next to the satellite then ethernet but same result.
I had success once before upgrading after purchase the router/satellite to v2.0.0.74 but now getting this error. Might try power cycling the satellite to see if that makes any difference before a factory reset (neither steps was indicated in the kb instructions).
Message 3 of 4
fydela2
Tutor
SOLVED Re: RBS50 Unable to update to latest firmware v2.1.1.16 from v2.0.0.74
After a power reset, I was able to update the satellite to latest v2.1.1.16 ... It then went ahead and updated the router (RBR50) as well. No need to re-enter or restore configuration. It is working nicely again.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 639 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
