- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS50 Won't Sync
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBS50 Won't Sync
My RBS50 behaves like everything is normal. It boots up. Power LED solid green. Top ring LED begins flashing white then after some seconds goes into pulsating white, which stays for a min or two and then no light at all. Pressing the sync button has no reaction what so ever.
Netgear has offered to have a chat with me for $89. That's nice of them, especially since their auto update feature in the app caused this issue in the first place by updating RBK50 first... I'm out of 90 day warranty as bought renewed set 5 months ago.
What are my options? Please help. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS50 Won't Sync
Factory reset the RBR and RBS and setup from scratch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
One thing I've noticed when factory resetting the RBS satellite, holding the pin until power LED flashes amber a few times, I let go, and the power LED just goes off, it does not turn green. So it's not initializing? It goes back on when I power cycle it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried loading the RBS FW manaully thru the RBS web page?
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR. I used this today on a RBS20 what was not on v16. It finally synced. I have it about 5-8 minutes before the top ring led when OFF.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good morming, well it didn't work. I can only successfully flash satellite via tftp (directly via windows and via recommended tftp app too), and only on 192.168.1.1 as this is successful and router's power led goes blank during transfer, and green one it's done.
I also noticed that my satellite is not factory resetting, as I had ethernet cable pluigged in, and did a factory reset, my network remained as is, without it saying calbe is unplugged. My Sync button also does nothing. This is turning into a headache.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, after you get the RBS recovererd with TFTP, it should come to a ready state with the top ring LED slowly blinking WHITE. IF you leave it for long enough the top ring will turn PINK. 5 minutes. If you get this, press the reset button on the back of the RBS for 15 seconds then release. This should kick off the factory reset. Same goes for the RBR.
Wondering if your system is in bad state. TFTP should get it recovered so that you get stock FW loaded then it should come to ready and the RBR will be accessible at 192.168.1.1.
If the RBS isn't connected, it will be accessible at 192.168.1.250 after 5+ minutes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, no matter what I do, the top ring light blinks white, then goes to pulsating white, then nothing and this nothing last for hours, so I think the RBS50 is dead. I wonder why it was refurbished in the first place. 😕
And purchasing brand new RBS50 - I might as well go with another mesh system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah, ya. Something that should have been sent back to NG.
Sorry it's not working. Hope you find something that does.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have exatly the same problem
after the router updated to V2.5.1.16 I lost connection to the Satellite then I connected the satelite to the router with a CAT5 cable an I was able to update the satellite to V2.5.1.16 , but still I can not connect the satellite I goes to the entire process but at the end nothing.
I have reset the satellite many time but nothing
any more sugestions. should a purchase another satellite og jump to google mesh system because I am afraid ti jump to WIFI6 (very expensive)
- Mark as New
- Bookmark
- Subscribe
- Permalink
CAT6 cabling is recommnended.
Is the RBS wireless or wire connected?
Has a factory reset and setup from scratch on the RBR and RBS been performed since last update?
@Pablo61v wrote:I have exatly the same problem
