- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS50 as a wireless bridge?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it possible to use the RBS50 as a wireless bridge? I'm asking because I need to use one of my RBS50s very close to my RBR50 and it seems that leaving them both on causes devices to drop off of the network, so, I was hoping to use one RBS50 as a bridge (for a HTPC, Tivo and PS4) and leave the wifi turned on at the router. Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS50 as a wireless bridge?
The RBS50 functions as a wireless bridge by default--just with an AP built-in. I believe you can turn off the 2.4GHz radio but not the 5gHz radio, because that radio is also used for the backhaul (which you need for the bridge function).
If your devices are very close together can you run a wire?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
you used to be able to turn off the 2.4 and 5 gig wifi and just have the 5 gig backhaul working and make it just a media bridge but for some reason the dev team have removed the ability to switch of the other wifi transmissions so it cant be done any more
it does however seem you have the orbi router and sat way to close and is why you would be having connectiviuty issues with the transmissions overlapping to much
