- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS50 keeps disconnecting frequently from RBR
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Orbi RBK52 system. A while ago the RBR failed and netgear sent a replacement RBR. Ever since I connected to the existing original RBS I am facing frequent disconnection ( the RBS drops connection every 20 mins. ) the connection between the RBR ant RBS is wired so there is no question of weak wireless signal between then both.
Please can anyone help me with this situation. Firmware version V2.7.3.22. The problem is only with the RBS, as all the devices connected to RBS gets disconnected from internet, while the RBR is perfectly fine.
Regards
Sujay
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS50 keeps disconnecting frequently from RBR
@sujay265 wrote:
Hello Folks,
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk & Non-Orbi). (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is FW version on RBS the same as on RBR?
What is the distance between the router and satellite(s)📡? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
@sujay265 wrote:
Hello Folks,
Regards
Sujay
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Furry,
My home is about 2400 sq.ft. single floor. The distance between the RBR and RBS is 45 feet wired ethernet connection.
I am using manual channels 2.4GHz = channel 11 and 5 GHz = channel 48
I have the Implicit Beamforming, MU-MIMO and Fast Roaming disabled.
I did a factory reset on both the RBR and RBS, apparently that did not fix the issue.
The firmware version on both the RBR and RBS are same V2.7.3.22
Yes there are atleat 10 Wifi neighbouring SSID that i can see.
The problem is frequent RBS discnnection every 30 min, i have to reebot the RBS unit to get it back online, which takes 8 minutes. This is so frustrating which this happens in the middle of a meeting. Please somone help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the RBS directly connected to the back of the RBR or is there a LAN switch in between the RBR and RBS?
Does this disconnection happen if you move the RBS to say 30 feet from the RBR and disconnect the ethernet cable from the RBS and let it connect wirelessly?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
The RBS is connected to RBR via a unmanaged switch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the ethernet switch in the configuration?
