Reply
Highlighted
RBS50 satellite firmware corrupted
HI, I have just bought a new Satelite for my home and it connected once. Then I moved it further from the router, but it didn't connect. Now even if I move it closer the satellite ring flashes white and when I start it, the power button flashes red, then turns green, but the ring light is still flashing white. After looking in the manual, I see that this means the firmware is corrupted. So how do I fix this? Finding tech support on Netgear is impossible. I bought the satellite on Amazon.ca by the way. I'm using a mac if that changes anything on how to do the resetting of the firmware manually is possible.
TIA!
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 5
Highlighted
NETGEAR Moderator
Re: RBS50 satellite firmware corrupted
Have you tried to factory reset the unit by holding the reset button for 10+ seconds?
DarrenM
Message 2 of 5
Highlighted
Hi Darren, yes I did, with still the same result.
Message 3 of 5
Highlighted
NETGEAR Moderator
I will need to get you in contact with support to work on this please send me a PM with the info below.
Name:
Email:
Phone:
Country:
Preferred Contact: Schedule: (Include Dates, Times and Time Zone available to work with us)
Orbi Model:
S/N number:
DarrenM
Message 4 of 5
Highlighted
Thanks Daren, I returned my RBS50 after contacting support. I will not buy another one though as after testing, I wanted to put it too far from my RBK50.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 902 views
  • 0 kudos
  • 2 in conversation
Announcements
