Reply
RBS50 shown under "Connected Devices", but not under "Connected Satellites"
m4f1j0z0
I have Orbi RBK50 in AP Mode with ethernet backhaul. I ran through all possible suggestions from this forum on how to get the enternet backhaul working properly (posts like this one https://community.netgear.com/t5/Orbi/Steps-to-reproduce-the-Orbi-backhaul-issues/m-p/1516065#M24646).
The Satellite RBS50 is connected, and it works fine over ethernet backhaul, but under connected devices on the Orbi Admin Page it isn't shown as a satellite, but as just another connected device. Why is that?
My setup is: ISP Modem (in bridge mode) -> Router Asus RT-AC68U (with Merlin) -> Orbi (RBR50 & RBS50 in AP mode). Cableing is fine, I have tested each ethernet connection separately.
As far as I can tell, speed and roaming performance are both fine (500 Mbit over WLAN), it's just pissing me off that the satellite isn't recognized as a satellite, and I dont understand why. Do you guys have an idea what's going on?
See the picture attached, the satellite has the IP 192.168.1.61.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 5
Accepted Solutions
m4f1j0z0
Re: RBS50 shown under "Connected Devices", but not under "Connected Satellites"
OK, problem solved. I just remembered that someone suggested not to connect the RBR50 to the router through the WAN port.
I just moved the cable to ETH1 port, restarted the RBR50 and RBS50, and voilà, the RBS50 shows normally under connected satellites.
Really this Netgear software / firmware is ridiculous. I might switch to Linksys Velop just out of principle.
Message 4 of 5
All Replies
Guru
Is the satellite working ok?
Is the satellite directly connected to the base or thru a switch?
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 5
m4f1j0z0
The satellite is working fine. It's connected to the ASUS Router, just like the RBR50.
Message 3 of 5
m4f1j0z0
Message 4 of 5
Guru
Good Luck.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1488 views
  • 0 kudos
  • 2 in conversation
Announcements
