- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS50 won't con't connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi router and satellite 1 upgraded firmware when satellite 2 was not installed. Now satellite 2 won't connect. White light on constantly and connection to router fails. Reset Orbi router and both satellites. Router and satellite 1 still have the latest firmware. I assume the cause is the different firmware. Anyway to upgrade the firmware without connecting to the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS50 won't con't connect
Yes. For one thing, make sure you have no ethernet devices plugged into satellite 2 when you power it on and attempt to sync it to the router. That alone could cause you issues.
If that doesn't fix it, you can upgrade the firmware on the satellite by connecting directly to it with ethernet (or wifi, if you're able to). Since the satellite isn't connected to the router, it won't have any DHCP capabilities, so you may need to manually set the IP address on your computer in order to be able to do this. So, first go to the Netgear site and download the appropriate firmware file for your model Orbi, then connect to the satellite, go to the satellite's configuration page, log in, then go to the firmware page and manually update the firmware you just downloaded.
You can also go into the router's configuration and have it generate a new backhaul password, then try syncing satellite 2 (with no ethernet devices conected), then satellite 1. I don't think a factory reset with have it generate a new backhaul password.
I also don't know that it works, or even is supposed to, but you can also try connecting satellite 2 to the router via ethernet cable and see if they can get connected that way. If so, you might just be able to go to the router's config page and then have it either check for new firmware, or manually update satellite 2's firmware from there. Once you get it updated, then you could try syncing them again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply, but I'm still lost. I have a Surface so I connected an ethernet cable from the docking station to Satellite 2. How do you set the IP address on the computer to connect and get to the configuration page? BTW Satellite 2's top light is a solid white light that doesn't go out...Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
I never tried to connect to satellite without the router, but please try to set the IP address manually on your Ethernet port settings in computer to say 192.168.1.20, then use a browser on your computer to browse to the default IP address in the Satellite which is 192.168.1.250.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still unable to connect. Also tried connecting to the network with ethernet cable and looking for the MAC address which I did not find. Does anyone know the significance of the white light on top staying on constantly?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@abil wrote:
...... Does anyone know the significance of the white light on top staying on constantly?
Please check here: https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Solid white. Your Orbi satellite is powering up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I know. The question is what is the significance of the light staying on constantly. It never starts blinking or never goes out. Therefore it never gets powered up? Does that mean the satellite is defective?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@abil wrote:
...Does that mean the satellite is defective?
Not necessarily, it can be that it's just not able to find the router.
- Please get the units close to each other
- Have you tried to connect the satellite to the router with a LAN cable as was suggested by @randomousity
- Can you please toggle the "Daisy Chain" setting in the router and see if that will have any effect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your help.
Yes, I tried all.
Tried to sync with satellite next to router. Tried to sync with satellite plugged directly into router. I also toggle the Daisy Chain setting causing the router to reboot twice. The white light on top of the satellite is still solid.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you know which firmware is in that satellite? If it's very old you might need to downgrade the router to an older software so that they can understand each other.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is old. I din't use the satellite for a year because we lived in an apartment for that time and didn't need it. Before I started playing with it the Firmware update page showed Satellite 2 as V1.xxxxxx eventhough it wasn't connected. It now doesn't show satellite 2 and the router and satellite 2 are on V2.2.2.210. After reading what I could on the intenet my original plan was to revert the software by resetting the devices to factory, however resetting didn't downgrade the software. How do you downgrade the software? I'm still concerned about the solid white light not changing and the unit being defective.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can download an earlier software from the download page here: https://www.netgear.com/support/product/RBR50.aspx#download
You can probably take the latest 1.x release say 1.12.0.18 to downgrade the router to then try to sync the "old" router then upgrade both to latest software.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for all your help. I tried the firmware approach but still can't see the satellite. I'm going to return the Orbi.
Thanks.
