Reply
RBS50Y with RBK852 compatibility?
Arverne63
Is External stelite Orbi RBS50Y compatible with Orbi RBK852?
Inother words, is it possible to add such satelite to an Orbi Wifi 6 network?
Message 1 of 5
Accepted Solutions
Mstrbig
Master
Re: RBS50Y with RBK852 compatibility?
We attempted to install an RBS50Y Outdoor satellite this morning, on an RBK853 system. We could not get the satellite to pair, even in Extender mode. Made several attempts, all failed. Not sure if the new firmware has something to do with it, but not matter what we tried, the satellite would not sync up.
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
Message 5 of 5
All Replies
Guru
If you load the Extender mode FW on to the RBSY first....
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 5
Arverne63
Thanks. I will wait an Orbi 850 satellite for outdoor as It is not urgent. For next spring.
Message 3 of 5
Guru
Ok, theres been no information or rumors on a Outdoor AX RBS that we know of yet. You'll have to keep an eye on the product pages for any annoucements.
Good Luck.
Testing
Message 4 of 5
Mstrbig
Master
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1118 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
