Orbi WiFi 7 RBE973
Reply
REPOST - Massive Difference between Download vs. Upload Speed
jdbauer6
I just upgraded for FIOS 1Gb.  All seems well at the FIOS router level.
However, the Orbi wireless speeds are vastly different for downloads (slow - typically 20-60Mbps) and uploads (400-500Mbps).  Any ideas why this is happening and what can be done to fix it?   It seems like it would not be a FIOS router or channel issue, since the speeds are fine on the upload side.  Downloads are obviously way more important!
Using MU-MIMO and Beamforming with SPEEDTEST app on 2013 Macbook Pro (sitting literally right next to an Orbi Satellite).
Thanks for any help!
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 3
linkwrt
Guide
Re: REPOST - Massive Difference between Download vs. Upload Speed
What country code you use. Try United States, try disable Mu-MIMO and beamforming.
Let other settings to auto.
Try also reset to default factory after upgrade.
Model: RBK44| Orbi AC2200 WiFi System
Message 2 of 3
jdbauer6
Tried all of the suggestions and still no improvememt.  For additional info - connected via AP mode to FIOS router.  MU-MIMO and Beamforming Off
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 779 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
