Reply
Rb50 wifi password works for minutes then stops on some devices
DoomGirDoom
Follower
  1. HopefullyI set that up correctlyBecause my orbee will not keep the password As Correct For Certain Devices. For some reason only my computer, my Echo show 5 and Galaxy S21 Ultra Are Having Issues. My LaptOp Is connected by LAN, I Don't Know what to do because I can't seem to find this enable Smart Connect which seems to be one solution I found but I can't find The Option For It Anywhere. And I've gone through pretty much every single Option. And I don't know why exactly my cell phone right now is actually Capitalizing random letters. And the weird thing about it is that I didn't even touch the damn thing and settings in the past little while and it's just suddenly doing it. just randomly is about 3-5 days ago it just started not accepting the password
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Rb50 wifi password works for minutes then stops on some devices
What browser are you using to manage the RBR?
Try setting a simple alphacharacter PW, 8 characters on the RBR.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 117 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
