- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rbk50 blocking firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rbk50 blocking firmware update
What type of wired devices do you have connected to Orbi?
Try disconnecting all your wired devices and see if the reboots will stop.
If that helps then start adding the devices one by one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm aware of the tutorial, but I haven't done it. Just to confirm, did you follow the steps and then commit the changes?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried a manual FW load of the Orbi routers FW with the FW files, then factory reset and setup from scratch? YOu shouldn't need to block FW updates and other say that manually loading FW resolves reboots. IT shouldn't be rebooting randomly at all:
Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highligh...
@Jpetrarca4 wrote:
Hi guys. Wondering if anyone can help. My system frequently reboots on the latest firmware. I went through and did the telnet steps to block the auto update. I downgraded the firmware and all was well for about a week. Today it dropped connection again and yup, it auto updated the firmware to the latest. I don’t understand. In the the tutorial to block this, there is confirmation steps to check the values of lines which I did and all was well. Any help would be appreciated. Thanks
