- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rbk50 can’t connect to nbn arris modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
My new Orbi RBK50 is not connecting to my NBN Arris CM8200. My internet provider is Iinet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rbk50 can’t connect to nbn arris modem
Doesn't tell us a whole lot.
1. Whats failing? details help not just it won't connect. Its like me calling my mechanic and saying "my car doesn't drive, tell me whats wrong?"
2. What firmware is on your orbi?
3. Are you trying to set via hardwired connection, app, wireless? Whats happening?
4. if you direct connect to your modem, does it work?
5. The arris cm8200 has 2 ethernet ports but only 1 works. Make sure you're plugged into port 1
Many times to fix the problems do this:
1. shut off both router and modem. disconnect all devices from both.
2. power on the modem. give it a couple minutes to fully boot.
3. Connect port 1 on modem to wan port on router. *Don't connect anything else to modem even once setup*
4. Boot up router. Give it a couple minutes to fully boot.
5. Connect to router with 1 device and try to go through setup.
did it work?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you power OFF the ISP modem and RBR for 30 seconds then back ON with the ISP Modem then RBR and walk thru the setup wizard on the RBR with a PC and web browser?
@Joshsqrd wrote:
Just wondering if you fixed this as I just bought the RBK50 today and had the same issue when trying to connect. Followed all the instructions from connecting the modem to router and followed setup for the wifi which was successful however when it checks for internet connection it fails. Please help
