- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rbk53 satellite position and signal strength
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am in the process of setting up my RBK53 system. I have a large 2 storey home with outside garage and outbuilding. Most of the walls are simple dry board/plasterboard and external walls are brick. I wanted to ask approximately how far should the satellites be positioned from the router. Can I measure the strength of the signal to the satellites to actually accurately determine where I'm best to position the satellites? Or is it more a case of experimenting with the position? I have heard on other postings that you can over saturate your property if it is too small for the power of the system. Again is there a way to actually measure for this or if you are having issues you move the satellites further away or switch one off? User experiences and technical advice would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rbk53 satellite position and signal strength
Hello Ian
It has a basic light system on if you have good signal or not but you would have to experiment on the best position.
DarrenM
