- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rbr20 constant purple led no connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an ADSL internet connection and purchased an Rbr20 + 1satellite a few months ago because I couldn't get the WiFi to reach all parts of our house (3floors). Soon enough the problems started: suddenly we'd get the purple led flashing on the router and lost the connection. Things seem to have got worse with the new software download. Sometimes the connection stays on for hours, and then suddenly we can't get it to work despite all the reloads we do. We work from home so we need to get this sorted ASAP, this is not sustainable at all.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rbr20 constant purple led no connection
purple usually means the sat can't connect the router. maybe move the sat closer?
If things seem to have got worse with the new software (im guessing you mean firmware) then perhaps revert back to the preious version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
@Izfair wrote:
Hi
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Izfair wrote:
..........suddenly we'd get the purple led flashing on the router and lost the connection. ......
If you see the purple LED on the router, then most likely your issue is similar to this: https://community.netgear.com/t5/Orbi/Another-RBR50-Dropping-Internet-Connection/m-p/1875385/highlig...
Please try the suggested solution in that post. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
@Izfair wrote:
Hi
Thanks
no copy paste...please
