Reply
Rbr20
Pocopatro
Follower
Rbr20
How do I connect this thing if I do not have a modem?? MyDlink is hooked directly to my dish
Message 1 of 3
Guru
Re: Rbr20
Orbi routers need a modem, ONT or some forum of ISP service interconnect or another router in front of it to connet to the internet.
Do you have satellite internet?
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.223/SRK30 V3.2.33.106)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, RBK50, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 3
Re: Rbr20
What is this D-Link?
Is it a router? If so, you may need to put the Orbi into access point mode.
Or, depending on what the satellite link delivers, if it just has an Ethernet input, remove the D-Link altogether.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 364 views
  • 0 kudos
  • 3 in conversation
Announcements
