- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rbr40 dropping service, ‘cannot connect’
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have had Orbi for ~6 months w/ no problems. Last week or so, speeds have fallen dramatically, and been very sporadic. Last 2 days, it has stopped working. After many fresh reboots (of both Spectrum modem and Orbi router) I may get it to test to acceptable speeds, then it goes away and cannot connect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rbr40 dropping service, ‘cannot connect’
What are your speeds UP and Down that you pay for?
What devices are you using to test speeds?
Be sure to test wired speeds along with wireless.
Try different devices to compare speeds.
