Reply
Rbr50 satellite to satellite
PaulBrassington
Just bought the RBR50 router and satellite but our cabin at the end of the garden is too far away. So I have bought a second satellite, please advise how to connect the second satellite to the first satellite to extend the range.
Warm Regards
Paul Brassington
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 7
Guru
Re: Rbr50 satellite to satellite
Should be able to enable Daisy Chain on the router and this should set up the satellites to piggy back of one another...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 7
Pfredd
Guide
Where is the Daisy Chain setting?
I can't find it on my CBR40
Message 3 of 7
PaulBrassington
Hi   All,
This worked for me:
http://orbilogin.net on   my PC, then Advanced tab, Advanced Set Up, Wireless Setup then click Enable Daisy Chain  Topology
Connect the first satellite to the Router
Put the second satellite in line with both (a straight line between all three , this stops the second satellite to connect to the router) then turn the second one on, click the first satellite sync button and then the second satellite sync button.
Open the app on   my phone and see the  network  map to ensure they are in line.
Hope this helps you  all.
Message 4 of 7
Pfredd
Guide
There is no "Daisy Chain" option on my CBR40. It has the latest firmware.
Here is a screenshot of the Advanced Wireless Setup screen:
Message 5 of 7
Guru
You need to post this over on the CBK40 Orbi with Cable modem. There are some differences between the CBK40 and the non cable Orbi systems. RBKs.
Message 6 of 7
Guru
Glad you got it working well. Enjoy.
@PaulBrassington wrote:
Hi   All,
This worked for me:
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2397 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
