Orbi WiFi 7 RBE973
Reply
Rbr50
Poppyozzy
Follower
Rbr50
After enabling guest user and then disabling, my Orbi rbr50 is now sporadic. I have rebooted and reset modem several times but still not as good as it was before enabling and disabling guest user. Any suggestions?
Message 1 of 2
Guru
Re: Rbr50
Press the back reset button for 15 seconds then release.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 308 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
