Orbi WiFi 7 RBE973
Reply
Rbs50
goibear
Rbs50
Burn marks on orbi satelite should i be worried.
Message 1 of 10
Accepted Solutions
CrimpOn
Guru
Re: Rbs50
Ugh.  Beats me.  Neither my router nor satellite look like that.  On the other hand, if it doesn't smell burnt, maybe it isn't.
Just don't place it next to something that will catch fire easily.
Message 8 of 10
All Replies
CrimpOn
Guru
Re: Rbs50
Burn marks where?
"out of the box", return it.
How long has it been working?
Message 2 of 10
goibear
Re: Rbs50
Its been running for 2 years. Not out of the box
Message 3 of 10
CrimpOn
Guru
Re: Rbs50
Oh, s**t.  "Burn marks" are never good.  On the other hand, there have been reports of the plastic case becomming discolored.
Does it smell burned?
Message 4 of 10
goibear
Re: Rbs50
No burn smell just black spots on the top side.
Message 5 of 10
Guru
Re: Rbs50
Can you attach some picture files of what your seeing?
Message 6 of 10
goibear
Re: Rbs50
Message 7 of 10
CrimpOn
Guru
Re: Rbs50
Message 8 of 10
Guru
Re: Rbs50
That would not be cuased by something under or inside the case. That looks like something landed on the top cover or maybe the top cover plastic had some corrupt materials in the mix and has degraded.
Is there any indiation of a burning smell coming from the unit?
Is this the only unit that exhibits this?
These marks only on the top cover or on the case as well?
Is the system working ok?
Message 9 of 10
goibear
Re: Rbs50
No burning smell still works. Will keep an eye on it thanks everyone.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1810 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
