Orbi WiFi 7 RBE973
Reply
Red Light vs Amber Light On Satellite During Attempt To Reset
Swenson0110
Follower
CONFIG:   (1) RBR50 With (2) RBS50
FW:   2.7.3.22
I reset all of the mesh devices in my home and started from the groud - up.  The router and one of the two satellights worked fine.  The other satellite gives me a red light indication when I attempt to reset it.  All the information I have seen indicates that the LED should flash amber (as the other devices did when I reset them).
I can't tell if there is an issue with the satellight or not. When I bring everything back online, the dashboard indicates that everything is working fine.
Has anyone experienced this?  Should I be concerned?
Thanks everyone
Model: RBS50Y|High Performance AC3000 Outdoor WiFi Mesh Extender and Add-on Satellite
Message 1 of 2
Guru
Re: Red Light vs Amber Light On Satellite During Attempt To Reset
How long are you pressing the reset button for on the RBS? 15 seconds then release should do it.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 338 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
