Reply
Regular Wi-Fi slowdowns on RBK50 satellite
sleszyk
Hi,
I can see this issue has been widely reported over the last few years but I was wondering whether anybody finally managed to find a reason or a fix...
Specifically in my case:
I have a RBR50/RBK 50 system with an RBR20 satellite added recently
My Internet speed is ca. 200Mbs
The system works like a charm except that every 3-4 days the Wifi speed I get on all devices connected wirelessly to the RBK50 satellite drops to 30-40 Mbs and stays there until the satellite is restarted (a simple restart fixes it, no factory reset required).
Devices connected to the router and the other satellite always get 200Mbs, as does the computer which is wired to the satellite in question (clearly ruling out any issues with the backhaul)
Initially I used to get this issue every 2 weeks, then every week and recently (roughly since the latest firmware update - although it may be coincidental) every 3-4 days. It is very very regular.
I did try a factory reset which didn't change anything (the speed keeps drops after 34 days)
I'm not contacting NG support about as I definitely don't want to waste a few months of my time, like many others had before, and get no solution in the end
Superusers / GURUs - please carefully read the post before replying with a bunch of random questions irrelevant to the problem (like size of the house, distance between router and satellite, Mu-Mimo, beamforming etc)
I know many ppl have been suffering from the same problem so wondering if anyone has found something useful over the last couple of years.
The only solution I can think of right now is plugging the satellite into a timer which will restart it every 4 days by switching the power off, but it's hardly ideal
Many thanks,
Peter
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Guru
Re: Regular Wi-Fi slowdowns on RBK50 satellite
You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883...
https://www.snbforums.com/threads/custom-firmware-build-for-orbi-a-la-faq.65224/
You can revert back to stock FW if it doesn't work out for you...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 4
sleszyk
Thank you, this is interesting... I wasn't aware of such an option. I will look into it in a free moment. It does sound a bit adventurous but, as you say, I could always revert back to the official firmware...
Best,
Peter
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 210 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
