- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Remove Circle from Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm this close to throwing this entire system in the trash. We got an Orbi yesterday, set it up with the Circle subscription that was included. It now won't allow anything (Disney+, Netflix, etc) to play on the on TV we set up with Circle.
We've rebooted the router, rebooted the TV, disabled Circle in the app - nothing works. When I go into Parental Controls in the Orbi app to disable, it says "this operation is not yet available over remote connections."
Someone please help me!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Remove Circle from Orbi
Factory reset the RBR and setup from scratch. Be sure to not enable Circle.
For any Circle questions or information, please refer to the Circle forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After searching for 15min on how to disable Circle so that I can enable OpenDNS and actually block harmful websites I finally figured it out.
Disabling in the Circle app is completely pointless. It doesn't work and kept showing enabled in the app and website based admin pages.
I had to goto settings in the Orbi app > Parental Controls > Disable Circle. That worked. Now, the Circle garbage is turned off and I can configure OpenDNS on the advanced tab without setting a static IP address for my inet service provider.
YMMV but hope this helps.
