Orbi WiFi 7 RBE973
Reply
Replacing an RBK50
Phyber
Luminary
Replacing an RBK50
I just purchased an RBK753-S at a really good sale price at Costco. It will be here on Wed. What I'm replacing is an RBK50 system. What do I need to do with the RBK50 system before I sell it? What about the Orbi app?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
ramalls
Re: Replacing an RBK50
Just replaced my RBR50 with the RBR850 WIFI 6 router.  One thing I can tell you is DO NOT TAKE SHORTCUTS.  Completely remove all connections from your previous mesh network and follow the instructions directly.  Would have saved myself a couple of hours had I not been in a rush to get the new mesh network up and running for a gaming session!!  Enjoy!!
Message 2 of 5
Phyber
Luminary
By removing all connections do you mean delete all the connected devices thru the app? I take it there's instructions on how to reset the router back to factory prior to selling it?
Message 3 of 5
Guru
I would start with factory resetting it.
Push and hold reset for 7-15 seconds while its powered on.
After that, I'd remove it from your account. here's the guide how.
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Registration-and-Un-Registering-prod...
If you do have issues with the new system, here's the forum too post in:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/bd-p/en-home-orbi-ax
Message 4 of 5
esmailhossain
Betreff: Replacing an RBK50
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 908 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
