Orbi WiFi 7 RBE973
Reply
Reset ORBI Admin password
HandM
Follower
My phone recently crashed so I had to re-install the Orbi app.  On the Orbi App, it's asking for the Admin password, which I do not remember.  How do I reset the admin password so I can finish re-installing the app on my phone?
Thanks
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Reset ORBI Admin password
If you setup PW recovery try this:
https://kb.netgear.com/24220/How-do-I-recover-my-NETGEAR-admin-password-using-the-password-recovery-...
If not, you'll need to do this:
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2092 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
