Orbi WiFi 7 RBE973
Reply
Reset admin password in the SET PASSWORD screen in ADMINISTRATION not working
w2usf
Tutor
I know my password and can sucessfully login. However the SET PASSWORD screen does not permit the change When I clink on APPLY nothing happens - no errors messages displayed and must click on cancel to escape.  The old passwaod in correct and the doulble entry for the new password matches.
Tries numerous times even with a wired connection. Mine is an RBR50 with 2 satillites and the latest firmware.
This is frustrating as the password reset should be simple
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 14
Guru
Re: Reset admin password in the SET PASSWORD screen in ADMINISTRATION not working
What browser are you using? Try IE11, FF or Opera?
Message 2 of 14
w2usf
Tutor
Firmware V2 31.44 just downloaded earlier in the day. Brower is  Chrome
Message 3 of 14
Guru
Message 4 of 14
w2usf
Tutor
Thanks for the tip.  I have several other browers installed.  They are not curative.
It seems unlikly it is a browser problem or that a simple password reset is browser dependant. In any case I see no advisories concerning incompatibility by NetGear.
It seems to be a software flaw ny NetGear is ignoring.
Liklly the cure is a hard rest.
Message 5 of 14
randomousity
Luminary
Just to check, you don't have your browsers or a password manager auto-filling the password for you, do you? Like, you think you changed the password, but it was actually overwritten by a saved password, so the password you submitted was really just your current password?
Also, you could try using the Orbi app to change the password if the web form isn't working for you. And, as another thought, some browser settings/add-ons can interfere with things. Privacy settings, cookies, ad blockers, tracking blockers, etc., have all caused issues with submitting forms (generally, not specifically with router configs) for me in the past.
Message 6 of 14
Guru
Will have to check on this. No body else has posted about this....
Message 7 of 14
Chuck_M
Mentor
Have you rebooted that router since upgrade?  May want to try that and see if it clears out whatever is preventing it from working.
If that doesnt do it, I would recommend a factory reset now that .44 is on there to eliminate any unknown variables.
Please let us know what you end up doing.
Message 8 of 14
Guru
Does yours work @Chuck_M
I'll check on mine this evening.
Message 9 of 14
Chuck_M
Mentor
I will check this functionality when I get home this PM.
Message 10 of 14
Guru
Setting a new Admin PW is working for me on the RBR50 with v44 loaded using IE11.
Message 11 of 14
Chuck_M
Mentor
Worked fine for me using Chrome and .44
Message 12 of 14
w2usf
Tutor
Thank you one all for the thoughtful comments.
I will do a factory rest as soon an I am able to retrieve the satellites that are in remote area of my home.
While the Orbi mesh system has performed admirably for some four months, I am disappointed in the Net Gear 90 support policy.  Effectively it adds up to no support unless one opts in to the service contract which begins to approach the cost of the product in just a few years.
I say this because these are consumer products intended for the non-technical consumer. Leaving the end-user to their own devices- having to experiment with an array of Web browsers as some of you have suggested- is hardly a consumer-friendly product. Routine password changes are not only necessary but a vital security feature in the pervasively hostile Web environment.  And such routine changes should be achieved by the popular consumer Web browsers in use. The answer is not an expensive Net Gear security product.
Knowing what I now know about mesh networks and the Net Gear ORBI, I may have well selected the Deco mesh products.
Thank you again. Spending your valuable personal time to respond is much appreciated. I’ll post the results of the hard reset
Message 13 of 14
Guru
It should work.
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 2686 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
