- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Reset mesh connections?
- Mark as New
- Bookmark
- Subscribe
- Permalink
And, another question. In reviewing my Attached Devices, I noted that my outdoor ORBI satellite, located in my shop, is attached to my router, while the satellite in between my router and the shop is connected to my farthest satellite.
Here's a schematic....
Optimal: Router -> Indoor Satellite -> Shop Satellite
What I have instead: Router - -> Shop Satellite -> Indoor Satellite
Is there a way to reset the mesh connections so that the system goes to an optimal setting?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Reset mesh connections?
What appears "optimal" to humans, may not appear so to electronics. That being said, you can try turning off both satellites. Power up the "closer one" and let it set for a while. Then, power up the "far" one and see what happens.
When you look at the Attached Devices web page, how does it describe the two satellite connections, "Good"?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good point - and yes, both are good.
@CrimpOn wrote:What appears "optimal" to humans, may not appear so to electronics. That being said, you can try turning off both satellites. Power up the "closer one" and let it set for a while. Then, power up the "far" one and see what happens.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If there are no performance issues, I would be tempted to move on toward another task. (except "cleaning the garage". THAT will never "rise to the top of my list.")
