Orbi WiFi 7 RBE973
Reply
Reset won't complete
bthom52
Follower
Can't access my router to update firmware. When my login fails I go to password reset page, enter new password, confirm new password, reset security questions and answers. But when I try to click on "next", the button is grayed out and nothing happens. What am I doing wrong?
Model: R6120|AC1200 Dual Band WiFi Router
Message 1 of 2
Guru
Re: Reset won't complete
If you didn't setup the security questions, it still asks them but there isn't a correct response.
You can try factory resetting the router to get back to the defaults.
Push and hold reset for 7-15 seconds while powered on.
Then follow the install guide.
Once installed, I'd recommend writing down the password somewhere safe.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 544 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
