Orbi WiFi 7 RBE973
Reply
Resetting Passwords
Karthik07
Resetting Passwords
Hi experts
I am in trouble and seeking all your help to reset the password of the orbi router, while configuring this device one of my friend was in my home, the service provider in my locality installed the device and configured the password now i want don't know the password what he configured to this device, i tried to reset the password as per the instructions on netgear support page, bit unfortunately i can't, because its asking security questions, i don't know whether this password recoveryoption is enabled or not, I can't even contact the service provider because they are installing 10 devices  perday, So whats is the option left to me to reset the password
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Accepted Solutions
Guru
Re: Resetting Passwords
Need to factory reset the RBR and setup from scratch an walk thru the setup wizard. This time be sure to write down all information for safe keeping.
Message 2 of 4
All Replies
Guru
Message 2 of 4
Karthik07
Thank you so much for your reply, will try it & let you know the results
Message 3 of 4
Guru
Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2091 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
