Orbi WiFi 7 RBE973
Reply
Ring light on the satellite
Wes_S
Follower
Just installed my Orbi RBK50 and RBS50 last night.  The instructions say that the ring light on top of the RBS50 will be blue if there's a good connection with the router.  This is what happened - it glowed blue and everything seems to work well, but when I checked the RBS50 a couple hours later the ring light was not lit.  The power light on the back is on, but the ring light is not on.  Is this normal?  Does the ring light on the RBS50 only come on when it's detecting the router?  Or, should it stay on all the time?
Thanks!
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
cinek
Apprentice
Re: Ring light on the satellite
that's expected. The ring light will go off after 3 mins or so. Nothing to worry about
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 503 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
