- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Roku Premiere Cannot See Orbi Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently purchased a Roku Premiere to replace my now dead Roku Ultra (trying to value engineer rather than paying the full $$$ for the Ultra).
Its all up and running fine, but my issue is that when setting up, the network scan is not even seeing my Orbi. The Roku is literally 3 feet away from the Orbi, so its not a distance issue.
I know the Roku Premiere does not function on the 5Ghz bandwidth, but I would think it could still see the Orbi and just run at the 2.4Ghz range.
I have connected the Roku to my TP Link modem (which is a wifi/modem), but by doing this I cannot use the Roku remote app on my phone as by default I connect this to my Orbi network due to better range and performance (and the app and the ROku need to be on the same wifi network to function).
Anyone any ideas or come across this? I cannot think of how to get the Roku to see and connect to the Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Roku Premiere Cannot See Orbi Router
Under Advanced Tab/Advanced Settings/Wireless Settings uncheck the Broadcast 5Ghz SSID. Apply.
What kind of SSID name are you using? Try a simple SSID name to see if the new Roku can see it.
Try setting up the same SSID name on the modem/router as you have on the Orbi temporarily. Then connect the Roku to the modem/router. When it's setup. Turn OFF the wifi on the modem/router and reboot or power cycle the Roku. See if the Roku will connect to the Orbis wifi SSID.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Furry. Those are some ninja level suggestions.
I will give them a try and let you know how I get on!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know.. Please give feedback for the question presented as well.
