Discussion stats
  • 8 replies
  • 376 views
  • 4 kudos
  • 5 in conversation
Announcements
Top Contributors
Reply
Highlighted
Initiate
Router Firmware Version V2.5.1.8 looses SSID for 5G
After configuring for separate 2.4 and 5G ssid per instructions:
config set wla_ssid="nameOf5GNetwork"
config commit
reboot
The router does NOT keep the new ssid and separation of 2.4 and 5G logins for WIfi.  It looses the newly created 5G SSID.
I have tried this configuration about 4 or 5 times.  It only keeps the differentiation for about 1 minute and then reverts to the ONE SSID for both 2.4 and 5G
Seems to be a bug in the v2.5.1.8 firmware.  The previous firmware worked just fine with each individual SSID
Does anyone have a remedy for this?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 9
Highlighted
Retired_Member
Not applicable
Re: Router Firmware Version V2.5.1.8 looses SSID for 5G
V2.5.1.8 has known issues
Message 2 of 9
Highlighted
Guru
Try using a single SSID name and PW. Separation of SSID on Orbi is not supported. NG seems to block this in FW. Downgrade if you need to.
v2.5.1.8 is stable and works will with single SSID name and pw.
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
config commit
reboot
My Setup (Cable 900Mbps/50Mbps)>CAX80>Orbi RBK50 v2.5.1.16(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK50/RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 3 of 9
Highlighted
Initiate
I did downgrade to a previous version and the separation of SSID-s for 2.4 and 5g  is back after I re-configured the separation again .  There should not have been a change in this in the new firmware upgrade as there are multiple reasons for devices to differenciate between 2.4 and 5g repsectively.
Message 4 of 9
Highlighted
Retired_Member
Not applicable
Stop doing manual updates
Message 5 of 9
Highlighted
Guru
NG doesn't support separation of SSIDs so NG maybe stopping this back end use with stock FW going forward. It's up to you though. Keep whats loaded or try useing the system as it's designed with stock FW.
You can also use Voxels 3rd party FW for Orbi.
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1839...
Good Luck.
Message 6 of 9
Highlighted
Guide
Check the thread on this:  https://community.netgear.com/t5/Orbi/How-to-set-a-separate-SSID-for-the-5-GHz-network-on-your-Orbi/...
You need to do an extra command on the new firmware, it's not as simple on the new firmware as NG go out of their way to set the SSIDs the same if you change them just using the old method.
Message 7 of 9
Highlighted
Which is more important, having updated firmware to prevent hacksrs or separate SSIDs?!
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 8 of 9
Highlighted
Guru
Orbi works with single SSID as well on old and new FW. Have never had a need to separate SSIDs.
Message 9 of 9
