Orbi WiFi 7 RBE973
Reply
Router Password Recovery isn't working with my RBR20
galenaforest
Follower
I've tried to login to my router and when it didn't work, I tried using Router Password Recovery. When it asked for my security questions, I provided the answers and a box droped down saying the answers aren't correct. Since the RPR doesn't work for me, what can I do to reovery my password?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 3
Accepted Solutions
Guru
Re: Router Password Recovery isn't working with my RBR20
Nothing. If you don't know the password and the recovery questions were either set wrong or not setup, you'll need to do a factory reset to redo the password. here's a thread that talks about the same issue.
https://community.netgear.com/t5/Orbi/Security-questions/m-p/1747239#M61063
Message 2 of 3
All Replies
Guru
Message 2 of 3
schumaku
Guru
@Christian_R  can't these firmware developers not simply hide the recovery questions as long as the related data fields re undefined or empty? Granted, this would require proper initialization of variables, and correct default files. Don't know how many hundred times we will see these user questions in the community - and NOBODY is able to correct this obvious usability issue?  And yes, this would apply to all products where this wonderful password recovery "design" is in place - Orbi, Orbi Pro, Nighthawk routers, Nighthawk Pro Gaming, Nighthawk WiFi 6, .... of course.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1048 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
