- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router admin screen doesn't show same info as Orbi app
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I log into my Orbi router through a website, it says that there are no satellites connected and only 1 connected device, even though we have approximately 30 devices that are connected to the wifi.
When I log into my Orbi app, it shows that 2 satellites are connected and the appropriate amount of connected devices, but they all show up as a printer or as a google home mini.
I unplugged and plugged back in the satellites until they showed a solid blue LED, so I'm assuming they are connected to the router.
Anyone have ideas why this is? Which one should I trust?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is on the "Top Support Articles" on that page, go to https://kb.netgear.com/000061838/RBR50-RBS50-Firmware-Version-2-5-1-16 to download the zip files. Extract the ZIP files, install the .img file on the satellites first, then on the router.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router admin screen doesn't show same info as Orbi app
orbi model number & firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Whawt browser are you using?
There is newer FW available:
@Brinch wrote:When I log into my Orbi router through a website, it says that there are no satellites connected and only 1 connected device, even though we have approximately 30 devices that are connected to the wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router firmware 2.5.1.8
RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Size of home is about 2500 sq ft.
One satellite is one floor above router.
One satellite is about 15 yards away.
Using Chrome
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do I revert back?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you turn OFF the one RBS thats shows connected, Reboot the RBR and see if the other RBS appears?
Is daisy chain enabled? If it is, disable it and reboot the RBR and turn on the RBS. Don't revet back. It's not a FW issue.
Becareful reverting FW,
@Brinch wrote:Size of home is about 2500 sq ft.
Using Chrome
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which firmware is best to revert to? Any favorites out there?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been on v2.5.1.8 since December 2019.;..
- Mark as New
- Bookmark
- Subscribe
- Permalink
v2.5.1.8 has many folks with tons of problems, like the one in this OP. stop being blind
- Mark as New
- Bookmark
- Subscribe
- Permalink
v2.5.1.16 was just released, it is supposed to fix the devices missing issue. I suggest downloading it first to see if it fixes your issue with 2.5.1.8.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@tomschmidt wrote:v2.5.1.16 was just released, it is supposed to fix the devices missing issue. I suggest downloading it first to see if it fixes your issue with 2.5.1.8.
perhaps a better idea is STOP with the manual updates altogether. too many folks have created their own problems
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't see that firmware version on this page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can get the files here and manully install them:
Install the the RBS first then RBR lastly then factory reset the system and setup from scratch. I recommend adding the RBS 1 at a time while checking the RBRs web page for status as each get connected.
Disable Daisy Chain on the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Brinch, did v2.5.1.16 fix your device issue? Please let us know. I am also running v2.5.1.16 since March 31 on my RBR50 and two RBS50 satellites (I was sent an early beta release to see if it fixed one of my open tickets for a different issue). For me, I have not seen missing devices with either v2.5.1.8 or v2.5.1.16, so I have not seen any change for my setup between those minor releases. I use the Android app, I don't have any iOS devices to try its app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had this issue and the new firmware (2.5.1.16) seems to have fixed it. On the previous firmware, I would see different devices in the app and the web but both were completely wrong, online listed 2-3 devices (I have 30 or so) and never changed after a reboot. Now I seem to be getting refreshed as they change. The icons / reported device aren't correct but I believe the IPs and MAC addresses are.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, updating to the new firmware did fix my issue. I wish I never updated the firmware though in retrospect. I've had random issues with the Orbi since then, and it's causing me a lot of frustration for the amount of money I've invested into it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Brinch wrote:I wish I never updated the firmware though in retrospect. I've had random issues with the Orbi since then, and it's causing me a lot of frustration for the amount of money I've invested into it.
Nice observation....thanks for sharing!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to make a backup configuration to file now.
Also if you have problems after FW updates happen or your manually update, be sure to factory reset the system and setup from scratch. This helps clear out any mis-configurations or incompatible configurations with the newer FW version. I prefer using the manual FW update method, make a backup, load FW then factory reset then setup from scratch. I can load the backup configuration from file and the system will works. If I run into problems, then I reset and don't load the back up configuration from file. I found that resets and setup from scratch is the best way to ensure the system is working well. There are other factors as well.
@Brinch wrote:Yes, updating to the new firmware did fix my issue. I wish I never updated the firmware though in retrospect. I've had random issues with the Orbi since then, and it's causing me a lot of frustration for the amount of money I've invested into it.
