Orbi WiFi 7 RBE973
Reply
Router speed
hnevis
Router speed
I have the above router + ORBI74 satelilite. Purchased mid 2017.
I upgraded to gigabit speed.  I get that speed hardwired to the modem.  However the Orbi system gives me 100-150 mbps.  Firmware is up to date.  Is this system too old to give gigabit speed?
Thank you.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 8
Accepted Solutions
Guru
Re: Router speed
Message 6 of 8
All Replies
Guru
Re: Router speed
Which Orbi router do you have?
Has a factory reset been performed then setup from scratch and run a speed test with a wired PC connected to the router?
Message 2 of 8
hnevis
Re: Router speed
Thank you!
The modem is a Rohs C3000.  The router and satelite are RBR50.
I did a factory reset on both.
With a wired connection to the Orbi router I get 626mbps download.
Through the satelite I now get 50-60 mbps, less than I got before.
Exasperating!
Message 3 of 8
Guru
Re: Router speed
Is the satellite wireless or wire connected to the base router?
Are you wireless or wired to the satellite when speed testing?
Remove the Orbi74 satellite and test with the ones that came with the newer Orbi system.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Message 4 of 8
hnevis
Re: Router speed
My home is 2900 square feet.
The satelite is not hard wired to the base.  It sits 25 feet from the base but there is a wall between them.
I will try to locate a newer satelite.
Thank you,
Very helpful.
Message 5 of 8
Guru
Re: Router speed
Good Luck.
Message 6 of 8
hnevis
Re: Router speed
Thank you!
Message 7 of 8
Guru
Re: Router speed
Smiley Wink
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1825 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
