Orbi WiFi 7 RBE973
Reply
Router vs Satellite
robeal
Follower
Router vs Satellite
I was wondering if the wireless signal strength is the same for the router and the satellite. In other words, should I consider the routher as the "primary" wireless source or can I treat them equally?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Guru
Re: Router vs Satellite
I believe you can treat them equally. Distance between the router and satellite is key. Placement of 30feet in between to begin with is recommended. Mines 40 feet. Great coverage and range for a 5000sq ft home.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3179 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
