Orbi WiFi 7 RBE973
Reply
Run two separate networks on one phone
Thevidpro
Tutor
I set up a network using AC2200 and satellites at work and works great. Just set up a second AC2200 system at home using the same netgear account. Returned to work to discover I am locked out of Admin on work network??? Short of resetting everything, am I missing something? I simply cannot login at work as an admin. Help!
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 3
CrimpOn
Guru
Re: Run two separate networks on one phone
If the Orbi app was used to set up both systems, the people on the app forum may have better insight than many of us on this forum who prefer to use the Orbi web interface.
Here's a link to the app forum: https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Message 2 of 3
CrimpOn
Guru
p.s. When you log in to the Netgear account, do you see two systems?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 446 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
