tuna_ertemalp's avatar
Jun 29, 2019
SNMP on RBR50v2 and RBS50v2?
I searched the forum for "SNMP", yet most "can't do" answers are left from 2017, and since then there have been many NOs that turned into YESes by hardware/software updates. So, I'll refresh the question...
The online PDF manual for RBRxx & RBSxx says, on the many pages under the title "default settings" that "SNMP: Disabled". That seems to mildly indicate that there might be a way, now or in the future, to enable it. I have just bought RBK50v2, all set up, works, happy, etc. It is a large house (I bought TWO RBK50v2!), so I am also replacing my misc ~15 year old unmanaged Netgear switches with Netgear's "Smart Managed Pro" 8/16/24-port switches. These are switches that implement the "SNMP v1/v2c and v3" for discovery & management by tools like LanTopoLog (https://www.lantopolog.com/) as well as more professional LAN mapping software (like, SolarWinds etc). So, I was wondering if the Orbi routers and sattelites will be visible in these topology maps when I am all done wiring up the stuff. I have looked at ORBI's router admin pages for settings, but nothing screamed as SNMP; maybe it is labeled as something different.
I know that orbilogin.com shows a list of the devices on the network, and I appreciate that VERY much; I already spent hours properly assigning friendly names to all the devices on my network. But a list is not a topology, and the iPhone app just showing which Orbi is connected to which other Orbi via wired or wireless is also not LAN topology. I want to see what device is connected to which switch/router/satelite either wirelessly or wired, and which port, if wired.
Upfront thanks for any insight about the current and future state of SNMP on Orbi.
Tuna
  • FURRYe38's avatar
    Blanca_O
    I would contact NG support for help and information on SNMP.
    If your using any managed switches, besure to disable IGMP protocols on these switchs. Users have mentioned this causes problems with Orbi. Along with green tech ethernet switches are not recommended.
    • dane-lennon's avatar
      dane-lennon
      Following up on this old post because hoping that someone made some progress with it? I'd love to be able to see network traffic per device and it seems I need to enable SNMP to do this.
      • CrimpOn's avatar
        CrimpOn
        As far as I know, none of the Orbi products have ever had a feature to collect usage information by device.  Nor do they include the Simple Network Management Protocol (SNMP).  In other words.  No chance in hell.
