Reply
SSH between connected computers
hype261
Follower
I am trying to ssh between two computers that are connected to my router.  Both are wired connections, but when I ssh I get connection timed out.  Is there something I need to enable to allow ssh between computers?
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 3
Guru
Re: SSH between connected computers
@DarrenM
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 3
rhester72
Virtuoso
If both are connected to the same router, they're connected to a layer 2 switch, so there's no firewalling - sounds like the host you're trying to ssh into is blocking via iptables at the system level.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 523 views
  • 0 kudos
  • 3 in conversation
Announcements
