- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Samsung Galaxy S8 not working on Orbi RBR40
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Samsung Galaxy S8 not working on Orbi RBR40
How did you fix it. Nothing I'm doing is working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Galaxy S8+ also disconnects off and on (more off than on) but no other issues with any other wifi device. After reading and looking at the router page I tried the following and it seems to have fixed the problem.
go to-- Advanced, Advanced Settings, Wireless Settings, scroll to the bottom and UNCHECK "Enable Implicit Beamforming"
After doing this the Samsung Galaxy S8+ connected and seems to be staying connected.
I am not sure what I may have given up by unchecking this? If you could let me know, I'd appreciate it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
This is the *one* problem I still have with my RBK53, even with the latest posted beta firmware. I have a Galaxy S8 (not plus) from Verizon that is fully patched and updated as of 6-8-18.
My S8 will disconnect, and it's very noticable when I'm using it as a remote for one of my Logitech Harmony hub's. The S8 does this when less than 15 feet away from the main Orbi router. Sometimes it happens over and over, and then other times it will go hours without happening.
Beamforming is and has been disabled (I've done extensive testing, both ways).
I don't need to do a factory reset or anything else Furry recommends.
It's not critical to me, but it is still very annoying, and helps me understand how others feel on these forums with all their Orbi disconnect issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Same type of problem with S9 and Note 8, seems working and next day no connexion.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
What FW is currently loaded?
How was the FW updated on the Orbi? Auto update or manual FW file load?
Has a factory reset been performed then set up from scratch?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#...
Does any of this help?
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM1200 Modem | Wifi Router Orbi RBK752 (Router Mode), Wired Backhaul and R8500 with Orbi RBKE963 (AP Mode), | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have add picture with the configuration.
But it seems disabling BEAMFORMING and disabling Fast rooming improve the situation, This morning the 2 phones are still connected to the WIFI without error.
I continue to monitor
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks for letting us about those settings.
Something someone may want to contact Samsung about and let them know so they can also review this situation with there phones running on Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I ahve the ORbi but have seen similar issues with eero. I can not get the S8+ to connect to 5G which I could force it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- « Previous
- Next »
