- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Samsung Galaxy S8 not working on Orbi RBR40
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Samsung Galaxy S8 not working on Orbi RBR40
@Luisfernan wrote:
@JMU1998 it doesn't matter if it's Verizon, Att or t mobile, it's the update Samsung did on July that it's not working with orbi. Just try the guest connection
I've been using the guest SSID for a month, and while more stable than the primary, it experiences the same problems a few days after resetting the orbi to defaults.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've found the same. Guest network doesnt disconnect but its still kind of flakey. I'm going to try to get Verizon to send me a new phone with old firmware to test the other guys results.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a hunch based on screwing with the situation for almost 45 days. The router is extremely stable for a few hours after a complete reset to factory defautls and reconfiguration. It gradually degrades over time following that...
Having reset the router numerous times since 1.11.x, that's been my experience anyway.
In fact, when the first .12 release for which I helped beta test, it was rock solid for several WEEKS UNTIL, I reset the Orbi due to installing new UPS's. Then it went flaky as all get out again, just like on 1.11.x.
Just FYI, I previously stated this began with 1.10, which was a typo, I meant 1.11.x.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Totally agree. Lets all contact Samsung. Maybe we can get the ball rolling faster.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ameetp wrote:Totally agree. Lets all contact Samsung. Maybe we can get the ball rolling faster.
Samsung doesn't have anything to do with the Surface Pro's, Ring, Amazon Echo's or the other devices. While they might be able to fix an S8 issue, they can't fix the others.
Given the S8 CAN function perfectly fine randomly on the Orbi with any firmware version, I still think folks are getting a single problem but are thinking it's only related to the S8.
Again, many devices are rock solid on the 1.11, and 1.12 firmware but some are basically unusuable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Resetting the Orbi and the satellites does not fix the problem. it did start with the latest upload from samsung for the S8 I actually decided to switch to using the Verizon WIFI until either Verizon or Netgear fixed the problem. I am able to get reception through out my whole house however it is weak in some areas. it is better then the constant drops
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am beyond frustrated and have wrote reviews on Amazon and Costco for people to stay away from this product - It is unstable and unusable for the past month. Support is slow and non-helpful.
- Mark as New
- Bookmark
- Subscribe
- Permalink
writing negative reviews may be the only way to insure this will get fixed. Companies are in business to make money if they get negative reviews they start listening. I will do the same
- Mark as New
- Bookmark
- Subscribe
- Permalink
Too many fake 5 star reviews...
Anyway, the Verizon August update for the S8/S8+ was just delivered. As I expected, a disconnected happened within about 10 minutes of receiving it. The problem isn't an S8/S8+ problem only.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was there a radio baseband update on the S8? If not, that would explain the Wifi being just as bad.
I realize people are upset about the orbi firmware but we need to make sure that confirmation bias doesn't cloud our data and we mix two different issues together.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd wait for somebody on Verizon with 'S8 only problem' to chime in. I can check later today when I'm back home.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router: RBR40
Satellite: RBW30
I'm having exact same issue. My Galaxy S8 Plus consistently drops the normal wifi. The guest wifi does seem to be holding, though it is underperforming the iPhone 6s Plus by a noticeable amount. It's working as a temporary measure, but this situation does need to be fixed with a new firmware very soon please.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My problem is only with the S8 and I have Verizon. all other devices work fine
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just installed the Verizon update on my Galaxy S8 plus. Connectivity still a problem. No internet connection after several minutes.
All other devices on the Orbi Network have always worked just fine, which includes iphone, ipads, Sonos, Alexa, Lutron Home Automation, Ring Door Bell, security cameras, 3 laptop, 2 desktop, numberous streaming devices and televisions.
The only failture on my home network is he Orbi with the Galaxy S8, continued internet connection drops. Thankfully, I have a iPhone that I can use on the network to control all the home automation devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Luisfernan why should I try guest connection I have no need for guest radio turned on to pollute my already congested environment with more interference. turning on guest connection is not an acceptable solution for my scenario.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Luisfernan returning phone is an option returning Orbi is not I got it when it came out. Not being able to reduce power on radios or turn off radios not being used is something Netgear removed which baffles me. I try not to be selfish and blast my router radio in all directions if I am not using them or have no need just contribute to the pollution/interference in your surroundings/neighbourhood/network environment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The guest network does not use a different radio channel than your current network, it just broadcasts an additional SSID. So, you wont be contributing to any extra polution that you arent already causing. Until netgear fixes the firmware, nobody here can really help much more as we are just all users just trying to help each other out, and not representatives of netgear
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can finally confirm that my Verizon S8 finally works without disconnect after todays Verizon update - It has been stable for the past 4 hours without a single drop in connection - I have walked all over my yard and through my home trying to get it to not respond.. I am also on the BETA firmware which had been working about the same up until the Verizon update this afternoon.
I have turned down the 2.4 intensity to 50% so that it stays connected to my 5 ghz more and I only have a couple 2.4 ghz devices
I even got full signal 100' into my backyard and speedtest'd with full DL and full UL speeds.
Here are my advanced settings:
- Mark as New
- Bookmark
- Subscribe
- Permalink
