- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Samsung Phones battery life sucks with Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Samsung Phones battery life sucks with Orbi
Try a reset and setup from scratch then setup those suggestions.
I just had my RBK50 online with v38 for a week and haven't seen any issues with batter drain. I have two samsung phones and a Tab S2 pad. All sees normal battery usage.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can I restore settings from back up after a reset? I've changed quite a bit since taking them out of the box. I'm concerned I'll miss something dduring the do-over.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. However if you still see odd batter behaviors, I would run a clean setup from scratch to see if the battery behavior changes or not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, uncheck the check box there and you'll get 40Mhz.
@Gillette2424 wrote:
I'm having same issues. How do I turn coexistence to 40hz? The only option I see is to disable 20/40. Does that automatically put it in 40? I couldn't find circle or a couple other settings anywhere either. I'll try with what I could find and see what happens. Thx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Things seem to have improved a little bit. But my Lenovo laptop still doesn't last like it used to when the ASUS was in place.
The only changes I ended up needing to make were to enable Beamforming and MIMO, set a specific channel for the 2GHz wireless, and disable the 20/40 coexistence. Everything else was already as you had suggested. .
Do you think a factory reset and (re)setup from scratch can really make that big a difference?
@FURRYe38 wrote:What Firmware is currently loaded?
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
It would be a last resort or last thing to try.
Haven't seen a lot of users posting about battery drain in a while. I do remember one I believe posted sometime last year or before about it.
- « Previous
- 1
- 2
- Next »
