- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Satellite (RBS50) loses connection and won't reconnect reliably
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm quite frustrated with my Orbi system: after getting the Satellite connected (blue light, appears on the connected devices screen), the satellite will then seem to drop the connection. It will glow magenta.
Other times, the satellite does NOT show on the connected devices screen, yet wired devices to the satellite are working (eg an Ethernet only wired security camera). During these times, there is no red or blue light from the satellite so I assume it thinks it is correctly associated with the router. I stress that when this occurs, the status page shows no connected satellite, and the static IP address I've assigned to the camera isn't shown on the connected devices screen (yet I'm watching its live stream).
In fact, as I write this, the satellite is pulsing a white light, but I'm watching a live stream from the Ethernet-only camera. Again, that camera's IP isn't showing on the Attached Devices page, nor is the satellite showing as connected.
I fail test the network by unplugging it, and the modem, and the satellite almost never connects back to the router. It's located about 60 feet from the router, on the same floor, high up on top of a kitchen cabinet. There is no other place I can put it as I need the ethernet jacks, and the satellite does go blue (sometimes).
I'm on Firmware 1.9.1.12.
I'm replacing a Google WiFi which was very reliable (and that mesh worked perfectly with placement in the same spots as Orbi) -- I just wanted to see the faster speeds of the Orbi. I think I'll be returning it unless I can get this to work reliably.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellite (RBS50) loses connection and won't reconnect reliably
Hello SteveW255561
I sent you a PM.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd be interested in what the fix is as well. Mine appears to be doing the same thing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm a new Orbi user and am having the same issue. I have been checking this forum and read a beta firmware would fix this issue, may I have a copy to try? Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm returning my Orbi system - it's just too unreliable for my family to tolerate: Netgear support did try and help and a beta firmware didn't solve the connectivity issue.
I wonder if my Sonos system (fairly extensive with 8 units) is causing some sort of interference with the Orbi, but the Sonos is configured to connect to the WiFi system and not its own mesh network. It works flawlessly with the Google Wifi I have in place (and am reverting back to).
It's a shame: when the Orbi system is fully working, I get amazing throughput of 178 Mbps! It's just too unreliable and I don't want to run the risk of missing my return policy. Maybe someday I'll circle back...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you ever find a solution? I am experiencing the same problems with the latest firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Currently I'm waiting on beta access so I can try that. If the beta doesn't resolve these issues I'm moving on to something else.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I am having the same issues.
I have reset the router and satellite a few times now, restarted the installation. Paired satellite.
It works for a while (few minutes) then I can't always see the satellite in connected devices and I can't log into it when I do see it. Devices attached to satellite and it's wifi signal and internet stop working. Have tried in AP and router modes. Have moved satellite closer and further with no difference. Had tech support on the line for an hour. Very frustrating.
Can't believe how this experience is turning out. Is this issue fixable with new hardware or is it an Orbi error??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Davidsch
Can you send me a Pm with your case number from when you contacted support I want to have your issues looked at.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
My satellite is doing the same thing and just keeps pulsing white. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
My satellite is doing the same thing and just keeps pulsing white. Please send me the help info. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having similar issues, I have two satelliotes. When I sync them, the satellite just keeps flashing white.
All my connected devices (iPhones, iPads) keep losing internet connectivity. This just started happening 2 days ago., I have been trying to reset and re-pair all the connections but to no avail. Can you help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Krishnaswami
Does the router have the same firmware version as the satellites?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm have extactly the same problem, using firmware v2.1.2.18, it works for a little while, then satellite just stops, it seems that devices failover; contect to the router (it's in AP mode), but this has very weak wifi signal. The status info given in the UI is very poor and I haven't found any usefully log information. I've very disappoint with these units. I've reset them numrous time.
If I go to the firmware download page, it shows v2.0.1.4 as the current version and v2.1.2.18 as previous version, HOW DOES THIS MAKE SENSE?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@pagabvwrote:I'm have extactly the same problem, using firmware v2.1.2.18, it works for a little while, then satellite just stops, it seems that devices failover; contect to the router (it's in AP mode), but this has very weak wifi signal. The status info given in the UI is very poor and I haven't found any usefully log information. I've very disappoint with these units. I've reset them numrous time.
Firmware 2.1.2.18 was put on hold due to the issues that people were reporting. Full story here https://community.netgear.com/t5/Orbi/OrbiOS-MR-2-1-issues/td-p/1506307
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello pagabv
What Roamabout is saying is correct you are able to revert back to 2.0.1.4 if that firmware is more stable for your system than 2.1 I suggest going back if not you can continue to use 2.1.
DarrenM
