- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Satellite WiFi no longer works after firmware update to 2.7.4.24
- Mark as New
- Bookmark
- Subscribe
- Permalink
My satellite has several devices plugged in directly and the Ethernet works fine from it. Any devices using the wifi from it can connect, but are connected without internet. I have tried messing with several settings in the advanced wifi (disabling/enabling bean forming, mimu, daiychaining, etc) but nothing worked so reverted it all back to what was working prior to the firmware upgrade.
Any advice for what to check is appreciated. I'm likely just going to factory reset but it certainly seems like something happened with the firmware considering that is the only thing that changed- so maybe I should just try reinstalling the firmware on the satellite first?
I posted this on other forums and it seems this may be a widespread issue with the firmware update that hasn't been noticed by Netgear yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellite WiFi no longer works after firmware update to 2.7.4.24
Hi Krieger0311,
Welcome to the NETGEAR Community!!
I understand that you are not able to get your RBRS50 working due to the update. Resetting your satellite close to your router has worked for some users experiencing this issue.
Please bring the RBS50 close to your RBR50 then reset your RBS50.
For more information about factory reset please navigate to the link below:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Best,
Kevin
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also found that some devices stopped connecting to the internet even though they were connected to the local network. Not sure whether it was the same satellite firmware.
Downgrading/reverting to 2.7.3.22 seemed to solve the problem; two satellites are still 2.7.4.24, so far.
Router 2.7.4.24 clearly has some problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello garyhooper,
I understand that you are having issues with your RBR50 on firmware version 2.7.4.24. Can you elaborate on the end user devices that are having disconnection issues with the most recent firware?
Best,
Kevin
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Several devices connected to the local network, but could not access the internet. These included at least an iPhone, Flume, Tesla Powerwall. Rebooting and resetting the devices made no difference.
As soon as I downgraded the router firmware, they all instantly were able to access the internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
These devices were connected to the primary WiFi network? (not the Guest network?)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Our iPad and iPhone have no issues with v2.7.4.24. Have no Powerwall and am GaGa over the Flume water usage meter. What a kick!
By chance is this Orbi administered primarily using the web interface or the Orbi 'app'?
Were there any devices that did successfully connect to that satellite with the new firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Again all devices appeared to connect successfully to the Orbi. It's just that some could not access the broader internet. I only tested six: iPhone, iPad, iMac could all access the internet; iPhone, Flume, Powerwall could not.
I was scratching my head until the second iPhone failed even though the first succeeded.
Hence the downgrade, administered via the web app. Instantly the problem was resolved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the thorough explanation. Pretty clear that the Powerwall and Flume cannot be relocated. That iPhone that failed, did have internet access when connected to a different satellite or the base router? It was only when connected to that one satellite that it had no internet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ran into the same issue. I had to set all my satellites and router back to the previous firmware. While using 2.7.4.24 I lost connection to my add-on satellite and multiple TVs that use to work no longer worked. After reverting back to the older firmware everything started working again.
