- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Satellite connecting at 2.4 Mhz
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently bought the RBW30 (firmware V2.0.0.34_1.0.21) wall satellite to add to my ORBI network. It has connected to the router (RBK50, firmware V2.0.0.74) but at 2.4Ghz not 5GHz. see following pic;
I have rest the satellite, resynch but had no luck. How do I get it to connect to the router at 5GHz? The Satellite is located 5 metres from the router with no obstructions.
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem solved. Factory reset corrected problem and updated region from Europe to Australia correctly.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellite connecting at 2.4 Mhz
why is it so close ? thank it further away and see if it will connect to 5 gig
sorry cant see pic
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply. I've tried to upload the JPG again.
The reason it is so close is because the NAIM NDS5 media server has a very poor connection to the router (the reason I bought the satellite). It now has an excellect connection with the satellite next to it. Moving the satellite further away will mean the media server will lose it's connection again.
Moved it 10 metres away and same result. Why would distance affect which frequency it uses?
- Mark as New
- Bookmark
- Subscribe
- Permalink
because wireless ac 5 gig is very sensitive to overload and interference
the image is still not showing but when you access the 30's gui what does it show on the backhaul
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure why this image is not showing for you. Works find for me...
The backhaul, if I understand you the connection from the orbi wall plug satellite back to the router, shows a wireless connection symbol with the upper part in blue (2.4 GhZ) and the bottom part greyed (looks like the 5 GHz section)
- Mark as New
- Bookmark
- Subscribe
- Permalink
