- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Satellite is slow
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I have an RBR50 and RBS50
The router works fine and get fast upload/download for the service I paid for.
the satelite howerver has always been slow.
from the router i get ~270Mbps down and 10Mbps up
from the satelite ~10 to 40Mbps down and 3-5 Mbps up
-i've moved it to different rooms (right now it's in the next room, pretty close)
-i've updated the firmware to the latest on both units
any help would be greatly appreciated
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellite is slow
thanks!
i switched to to using channel 1 instead of auto
that seems to have helped.
- Mark as New
- Bookmark
- Subscribe
- Permalink
