- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Satellite - network link down multiple times per day
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have my Windows laptop connected directly via ethernet to my satelitte, however I've been noticing multiple link down issues each day since I cabled directly rather than rely on wireless:
Intel(R) Ethernet Connection I219-LM
Network link is disconnected.
Deciding to troubleshoot more eventually (it normally drops out at the worst time during work calls) I cabled in another Windows desktop to the same satellite unit (so different LAN port), and low and behold at the exact same time the link disconnects on my laptop, the same happens on the desktop:
Broadcom NetXtreme Gigabit Ethernet: The network link is down. Check to make sure the network cable is properly connected.
To me this tends to point towards a defective Satellite unit - has anyone seen this before or should I just log a warranty call?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellite - network link down multiple times per day
Hello Somewhat
What firmware version are you on we have release the 2.0 update on the community if you do not have that. Also make sure you have mumimo and beamforming enabled in the advanced wireless settings of the orbi unit.
https://community.netgear.com/t5/Orbi/OrbiOS-2-0-availability/m-p/1368730#M13446
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Darren,
Thanks for the reply. I was running Router Firmware Version V1.12.0.18 and wasn't aware of the 2.0 release thanks - I've manually updated and will monitor it for the link drops.
Re "mumimo and beamforming" - these aren't enabled (default from memory) but note my issue is to do with Wired connections to my sattelite intermittently disconnecting so not sure this would be related??
Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think I am running into the same problem with my printer, wired directly to the back of a satellite :
I'm on the 2.0.0.74 firmware already, though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interesting, thanks! I upgraded to V2.0.0.74 and unfortunatley no change, see screenshot - still dropping multiple times a day.
Surely can't be a common firmware issue, perhaps we have bad satellites?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you are still having disconnect issues after the 2.0 update and a factory reset send me a PM with your name, email, and phone number.
DarrenM
