Orbi WiFi 7 RBE973
Reply
Satellite not staying connected
ttredway
Follower
Model # RBR40 My Satelite is not staying connected.I had Spectrum out today and its my Orbi? It was working fine but keeps showing yellow on my phone app.
Message 1 of 2
Guru
Re: Satellite not staying connected
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 403 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
