Orbi WiFi 7 RBE973
Reply
Satellite really slow-says wired!!
pablofuente
Since the update to latest FW, my speed has dropped dramatically.
Something weird is happening, one of the satellites (the one downstairs) says "Connection type: wired" instead of 5G like the other, that is not possible...I use star topology (daisy chain off) via wifi (the router is in mid level and satellites-2 units-are based downstairs and upstairs). I also notice that the IP of that satellite is changing quite a lot.
Any help?
I tried to factory reset the problematic satellite but notings works...
Thanks
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 5
DarrenM
Sr. NETGEAR Moderator
Re: Satellite really slow-says wired!!
The satellite that has slow speeds is it on the wireless and the wired connection? Have you tried to re position the satellite?
DarrenM
Message 2 of 5
pablofuente
The slow satellite says "connection type: wired", but it is simply not possible since there is no other cable attached to it than the power one.
I cannot position it anywhere else given the installation.
When checking the firmware version on Advance Menu-Firmware update, I see that router and satellites are on V2.1.2.18 but the status of the slow one says "Please wait a moment" a never changes, while the router and other satellite say "No new firmware version available".
I also tried to connect to slow satellite through its IP address I saw for that satellite on "Attached devices menu" and I couldn´t...then I went to manual firmware update and the IP address differed from the one in attached devices menu.
Thanks for your help
Message 3 of 5
pablofuente
Adding to my previous post...I have spent some time on the Netgear Orbi advance setup page, and I see that the IP of the slow satellites jumps constantly...
Message 4 of 5
st_shaw
Master
As already suggested, move the satellite (and/or move the router) to get a better backhaul connection, and see if that stabilizes the connection.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1049 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
