- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Satellites have disappeared after auto update to 1.12.0.8
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello
My satelletites seem to have disappeqared. the main router (RBR50) admin page says iti is on 1.12.0.8
I saw an article that down grading to 1.11 may help, but i cant reach the satellites - so how do i downgrade them first? . Can i downgrade the router manually first?
Is there any other options?
how do i then disable auto updates?
THanks
rspam11
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellites have disappeared after auto update to 1.12.0.8
Hello rspam11
You can not disable auto updates. Are you able to access the satellites by going to there ip address? try typing 192.168.1.x where x= 2-10 and see if one of those ip address brings up the satellite.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is the same issue that has generated a 312 (and counting) comment thread relating to the firmware upgrade. To date, I don't think it's even been acknowledged by Netgear to be an issue....
- Mark as New
- Bookmark
- Subscribe
- Permalink
@rspam11 wrote:Hello
1. Download old firmware for satellite and router (two files)
2. Connect to satellite at 1.12.0.8. If that is not the address, go to the list of connected devices and identify the ip address and use it to connect.
3. Use the router password to log-in directly to the satellite.
4. Update the satellite firmware to the old firmware (1.11.).
The satellite should now work.
You can also update the router to the old firmware.
There does not appear to be any way to prevent the router/satellite from auto-updating to the new firmware and breaking the satellite.
Netgear has not responded in this forum to this problem, has left the firmware on the website, and otherwise there is no fix in the works. If you can return the product, that may be a better option given the lack of technical support and irresponsible actions by Netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you're having issues getting your Satellites to connect, I suggest that you bring the satellites near the Router and do the f/w upgrade. Then, once they've upgraded, move them back to where they need to be.
For what it's worth, I'm running 2 systems on 1.12+ at home (dog food testing) and had no such problems with Satellites disappearing.
-Orbi Product Team.
- Mark as New
- Bookmark
- Subscribe
- Permalink
