- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Security Tab missing
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've notices since putting the router in AP mode, I can't see the security tab. Is this normal? Can I run Armor if the routers is in AP mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Security Tab missing
@OrbiRocks wrote:I've notices since putting the router in AP mode, I can't see the security tab. Is this normal? Can I run Armor if the routers is in AP mode?
There are many things the Orbi no longer does when in Access Point mode, including Armor and Disney Circle. That's what "Access Point" is rather than "Router." Since most people are better off with only one router, they have to decide which "router" they want the most and put the other device into "Non-router" mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I only have the Orbi connected to my internet modem through the WAN port. I had to put it in the AP mode to be able to get my direct tv box to connect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@OrbiRocks seems to have several things going on at the same time.
Connecting DirectTV - NETGEAR Communities
Nothing wrong with that, but it helps to join up the dots. I suspect that these issues are related.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Built in router here by chance? if so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
I would try option 1 first, if that can't be done, try option #2 if you want to use the Orbi in router mode.
@OrbiRocks wrote:I only have the Orbi connected to my internet modem through the WAN port. I had to put it in the AP mode to be able to get my direct tv box to connect.
